VMAX535
I am putting a 02 Viper skid in my 1996 VMX800. Could some one check their Viper and advise the mearurement between boltcenters on the upper assembly and the measurement from the top of the tunnel down to the bolt centers. This would the be measurements as illistrated in WildMax's ProAction Tech post. One the pictures is posted for refernce. Distance between B and C. As you can see the rear shaft on this skid has 3 bolts securing a bracket that positions the rear shaft. From the attached picture of the Viper skid there is only one bolt holding the rear upper shaft to the tunnel.
Thanks,
vmax535
Thanks,
vmax535
n2oiroc
if i could see the pic i would help. try blowing it up a bit.
yamvip
not sure what your asking for,the distance between the last two mounting spots???
VMAX535
yamvip
So you need the distance from b to c on a viper???
If so i'll get it for you jus tlet me know if that is what you need??
VMAX535
Yes, distance between B - C and the distance from the top of the tunnel to center hole C.
yamvip
k, here they are b-c 15 3/4 c- 3/4 from the floor boards,and b- 3 3/4 from the floor boards. I hope this helps ya out. I measured from the middle of the bolts.
n2oiroc
b-c is 15.875". top of tunnel to rear hole is 6.375" and top of tunnel to center hole is 4.25".VMAX535 said:Yes, distance between B - C and the distance from the top of the tunnel to center hole C.
VMAX535
Thanks for the measurement.
/Dano
/Dano
VMAX535
More Info Needed
I was hoping that the middle Shaft "B" would have a distance of 3.94" from the top of the tunnel to the bolt center. n2oiroc you have measured 4.25"
Due to the difference of 0.31" I need a couple other dimmensions' verified.
The attached photo shows 4.5" between the center of the speedo housing (drive axle center) to the front swing arm of the skid noted as shaft A. Please measure this distance on the Viper and also advise its dimmension above parallel. (By this picture it appears to me that the shaft "A" is 0.5" higher then the drive axle center, this is the dimmension that I refer to as "above parallel) Also please provide the distance between "A" and "B" the attached picture shows this distance at 11.5"
The picture shows a dimmension of 2.88" from the bottom of the chassis. It can not be measured this way as the VMAX-4 and the Viper use different tubs.
I hope this makes sense and I appreciate your support.
/Dan
I know that this is working backwards but I assumed that the "A" and "B" shaft dimmensions would be the same either sled.
/Dan
n2oiroc
axle center to A is 4 5/8". A-B is 11 9/16". B-c is 15 7/8". here are inside top of tunnel to center of mounting points. A 5 3/8". B 4 3/16". C 6 1/4". the 4 1/2" i gave you before was from the outside. these are from the inside.
VMAX535
Thanks for taking the time to measure up. No pun intended!
VMAX535
VMAX535
