Fast_Eddy
I was just out trying to take the sliders off my dads 2000 mtn max with the 141 and it has a camoplast track.. so the sliders will not fit through the holes in the track.
I have take off the bogy wheels and tried to slide it off to the side but the track wont go over more cause its hit the tunnel.... any help????
Fast_Eddy
come on im sure somone has done this befor..
bbender_sxr
Fast_Eddy said:come on im sure somone has done this befor..
yup, this weekend, actually.
take the four bolts out that are on the tunnel that hold the skid in. from there i was able to put the sled on its side and swing the skid waaaay out. then i disassembled the rear axle and was able to pull the track off to each side enough to pull each hyfax off. then i reassembled putting the rear two bolts back in first... it made it easier to line everything up.
Bluebozz
- Dec 4, 2003
hyfax
notch one track window on each side so the slider will fit through
bbender_sxr
Re: hyfax
good idea, but the the lugs will stick out too far on that mt max... my 1.25" lug was too tall for the slide to come out, even if the window was wide enough.
Bluebozz said:notch one track window on each side so the slider will fit through
Bluebozz
- Dec 4, 2003
track window
so you are saying the track lug covers the opening?, seems like once you get the slider out the window you could bend it up or down enough to get by the lug, gues i am glad I only have a 1.25 lug
Fast_Eddy
The spacing in the lug still let me get by with some of the holes in the track. got it all done now wish i would have cut the hole in the 1st place
