Removing Radius Rods
ReaperSRX
New Liskeard, Ontario
Is it just me or is it just a pain in the butt trying to get the nut off the bolts that connect through the bulk head. Access is tight even with the manifolds off and steering and boy are really tight on, must be a ton of loctight...........any advice..........james
Be sure to have mechanix gloves on in case you slip. Then all you have to do is get into that "mood". You know the one required to accomplish things requiring significant amounts of strength. Make sure the wrench is on good or you will need new nuts.
Yes i learned the hard way when i first started taking apart to wear gloves. I think i will go over to the father-in-laws farm and pick up a long bar socket wrench should give me more leverage and a buddy with a second set of hands is alway a good idea :beer: ..........James
