full tilt viper
Regular heel clickers or Heavy hitters for a triple piped viper?I have both setups and have trouble setting up both perfect. Can someone tell me the differance in shift charistics and profile. Also if anyone has a good setup for each one that would be helpfull.Looking for 8700-8800 (bender pipes) good to about 1000 feet. Running a roller rooster sec 41\37.weight 180lbs.
Thanks!
Thanks!
OK..I will try to help. What is your primary set up like right now with both set ups & what is the tach reading from a dead stop to top end? Very important!!!!!......Don,t do this on a tight windy trail!!!!! Also you gotta tighten up that roller ...i recommend a silver at 60 wrap.
full tilt viper
clutching
The rpm is 8650 out of the hole finishes at about 8800 . When I ran the bender 8ek's it would over rev on top to about 9000. Seemed to have much more control with the h h . With the heavy hitters the more weight i moved toward the tip and out of #2 the better it ran and maintained good rpm.The heel clickers i ran were the 2 speed weights and they came apart. They gave me the original heel clickers as a replacement. I seemed to me when i was running the 2 speed weights that the clutch would run very hot and I was'nt sure with hardly any weight added if it was shifting all the way out!
