Best way to drain oil???
yamvip
Wauseon, Ohio
I'm changing oils,and would like to know what is the best way to drain the oil,without getting air into the lines???
Yeah i was thinking the same,but i want too start off the season with this new oil I'm trying,also was told for best results too pour a little down the cylinders and pull it over a few times,if wondering??I'm trying Blue Marble.
ive used one of those cheep 3 dollar siphons with the pump ball on it and pumped it out that way, down till just above the oil feed line and fill it up with what ever your changing to
yes, its done.Well this season should be interesting,Lets see if this Blue Marble is all that is cracked up too be??I'll keep posting progress through out the season.
