sockeyerun
Test Dummy
What are you guys with MM's running your limiter straps set at? Hadn't messed with mine since it was new. The proaction suspenion book says 30mm. Mine were set at 10mm. Thanks
intoodeep
On my 151 no DnR I run em all the way out. Helps keep the nose up when ridin in deeper snow, just watch for the trench and steerin on the trail (put on Simmons to help with the trail to the hill and to keep the nose up)
When I'm pullin the steep hills, I suck em up for a little lower approach angle and less transfer.
Works for me
Works for me
sockeyerun
Test Dummy
What about for trails? If your running yours all the way out for the deep, why would Yamaha recomend 30mm for the MM??? I do ride mine more on trails and lifts and pushes bad in the corners,which was because of the long track, I know it will do some. Ski lift is not a problem, there always up. Thats part of the problem.
