The drain plug is in a bad spot and I'm wondering what everyone uses for a drain pan to hold a gallon of fluid even though it looks as though a cool whip container wouldn't fit. Just do two small containers and keep switching dumping into a larger one till its done draining?
BTW PV's and manifold are out of the way. Thanks!
Borrow a buddies shop vac, and suck it out the resivior. LOL Maxdlx
monkey man
- Oct 27, 2005
pull line off carb and drain it out exhaust hole in belly pan
