C&A pro ski mounts dont work
kinger
Clear Lake, IA
Wondering if this is a common theme, it seems my rubber bushings for my C&A pro skis will not fit into the spindle bracket. They are wider then the stock rubber bushings, do I just trim them the 1/4" they are too wide?
Also wondering if the thick washers go inside or outside the plastic walls the spindle fits in. There were no destructions with the skis so I'm just a little confused. Thanks
Yep , just trim them, (I used a hack saw) You'll also have to trim a V into the center front and back so you can change the carbines without taken the entire ski off. This is with the sport, not sure which style you have. It's a little work, but I liked my C@A's
1CS
Got them on and they turned out great! Just need to get them shimmed if she still darts, otherwise they are ready to go. Nice skis!
I LOVE my C&A's, had them on the last four sleds now, great handling and bite in the corners, and look great. ;)!
I have C&A advantage skiis on my sx. I used a chop saw to trim the rubber down. Now i just have to wait for snow to try them out! lol
