TimeBomb
i noticed in the pics of users that have this kit on their vipers that where the extension bolts to the existing rails that there is only bolts holding it there. have you guys with this kit had problems with them loosing up? could it just be welded plus the bolts? and maybe a shaft connecting the 2 just infront of the rear axle? it just doesn't look strong enough to me. what do you guys with this kit think?
..SNAKEBIT..
got the track and tunnel extension from rich and went with Tracks USA ext. and I think I put 6 bolts in each rail
NO problems
NO problems
Agreed, I run the Tracks USA extensions as well, they are machined to fit in the old axle slot for added support as well, and then bolt in. Much nicer than the MPI's IMO
richierich
There's more then just the bolts.It's machined to fit into your old track adjuster slot.There hasnt been any failure's with the kits.If you want one i have one that i'm closing out for $310 shipped.Also have the track if you need one.
