Oil pump adjustment help
kysledneck
Georgetown KY
Oil pump adjustment help! No one has done this? HELP!
I finaly bought the original manual 1997 Sx 600, It shows there is an adjustment for the oil pump, there is a line that should line up w/ wide open throttle I have no more adj left! at Idle there is a line I got that one to match seems to smoke less! 1st pic is idle 2nd wide open it goes past the specified line!
how much oil does it use when you are riding? If it doesn't use too much don't worry about it. Shoot for around 100-125 miles to a quart in normal trail riding conditions.
First Thanks for responding I was suprised noone knew this one! 2nd I have not ridden it much only 50 miles after I bought it last year! I just do not understand what to do I am out of adjustment & it is not like a bicycle brake where you just loosen up a nut & pull the cable down & re tighten! But man it realy smokes I know it is warm but man oh man!
line up the marks at wot, no more than that mabie even little less
there is two rubber sleaves on the cable you have to pull them apart to adj. the cable wish i had a picks for ya
I will go check that! Thanks!
