98 SRX 700 Water Pump Shaft
bowtietr83
I have a 98 SRX 700, and the water pump shaft is not spinning. I am assuming the gear on the shaft is stripped, and this is the reason. The question is, can this shaft be removed without splitting the case? I know the middle bearing has a circlip on it, so I am assuming it can be. Any help in this situation is appreciated. Thanks in advance.
