woolyviper
Without changing the cables, How big can I go with a riser block on my 03 Viper?
acnas
I think 2 inch is the most without any problems.
SRX RIDER
Any more than 2" and your oil pump cable will start to pull apart.
..SNAKEBIT..
I went with 2" and still had to re route cables some dont think any taller would work without extension
NLViper82
I put a two inch on and had no problems. I never had to reroute anything. But I would not be able to put another 1/4 of a inch on there, the oil cable is at its limits now.
yamvip
I have a 2 incher and no issues.
yamyrider
I just installed a 2" on my SXR without problems.
Was only about 5 minutes of work to add the riser.
yamaholic22
2" makes a big difference on these sleds, i have 4" on my viper and its much better.
redsnake3
i got a 3 inch on mine and the cables are fine,
the wires.....
thats the problem i had
had to cut them all and add 2" of wire to them all.
the wires.....
What's the best 2" standard block riser for a viper? Aren't they all about the same?
SRX RIDER
redsnake3 said:i got a 3 inch on mine and the cables are fine,
the wires.....
had to cut them all and add 2" of wire to them all.![]()
Sounds like fun! I just wired in a tether and only had to splice 2 which was annoying. I can't imagine having to do them all. How did you re-route your cable if you didn't lengthen them? Oil pump cable has to be pretty tight with a 3" rise not? I think my brake line was getting a little snug too.
yamvip
There are some pretty nice risers out there,i went with the powermadd,i'm not sure how much it was but it was cheap.talk to Rich he'll set ya up.
yamvip
Just checked his site,13 bucks,plus shipping.can't go wrong with that!!!
SRX RIDER
You will love the difference the riser makes. I can't even stand to ride a Viper without one anymore.
redsnake3
yeah i left the cables were they were routed through the guides on the airbox, the brake line has just a little slack at full turn.
that was real close had to move the brake line a little to get it too fit. at first it was pulling on it and makin it leak, good thing i found it before i was on the trail.
97vmaxxtc
yamvip said:Just checked his site,13 bucks,plus shipping.can't go wrong with that!!!
When I try to order it comes up as $26???
..SNAKEBIT..
with my 2" riser my oil cable would pull out had to reroute it??
dont know about anyone else, but I have my bars turned up where the brake handle just hits the stock windshield when turned, and had to tape the oil cable connection
maybe with the bars leaned back 3" might work but I wanted the bars foward as possiable
PS my cover barely fits over the bars now
