2001SRX=Fast
Okay... Yes i know it smells like strawberrys! Tell me all everything else about it.
yamyrider
um......oh...ah.... its great oil.
I dont know the technical details of the oil but have heard from guys who race and run hard and some guys that spend all their time tweeking and they love the stuff. The engine parts stay nice and clean with this oil.
It is very popular in Eastern Canada.
Whats this thing about adjusting the oil cable when going fully synthetic? True with Ipone, I'm looking forward to riding with a no smell oil to keep the peace between my 4 stroke riders
n2oiroc
you supposedly can run less oil with a synthetic. i just keep mine at the stock setting. more oil is good for the crank and i believe good oil in reasonable amounts helps keep the valves clean. i think gas is the biggest thing that dirties up valves.
SRX7
Go to their site...........
SNOW RACING
Fonction : 2 Stroke motor oil - snowmobile
Properties : Semi-syntehtic (-54° C) Anti smoke / Option : Strawberry exhaust smell
Satisfies to : API TC
Usage advice : Synthetic based lubricant specially formulated for 2 stroke engines, for snowmobiles functioning in conditions of extreme temperatures (-54ºC). Advantages : - anti smoke, it preserves the environment - strawberry smell to improve the comfort of groups of drivers, - improves the longevity of the plugs SNOW RACING is a top range product that does not foul up and ensures an excellent valve function.
SNOW RACING
yamaholic22
Exactly as David said, they tell you that you can adjust your oil pump to a lower setting with synthetic oil simply because it is better oil. I usually shoot for 150 miles to a quart on good synthetic oil
Oh OK, i'll check my consumption and see where I'm at. Thanks
2001SRX=Fast
okay
So what do i have to adjust when i run this ipone stuff or can i just leave it at stock settings and put it right in?
n2oiroc
run it at the stock setting first and then watch your consumption. if it uses more than 1 quart in less than 125 miles (during normal trail riding!), then adjust the oil pump cable for lower consumption. dont do lake runs for oil consumption tests or you will be real lean on oil!2001SRX=Fast said:So what do i have to adjust when i run this ipone stuff or can i just leave it at stock settings and put it right in?
Next challenge is getting it shipped to me in the US!
2001SRX=Fast
Kinger.... I found a place for 8.99 a liter. Super cheap.
SRX7
Leave your setting stock.Be safe.
2001SRX=Fast
yea thats what i figured.
SRX7
I used IPONE late last year. The smell is great & it certainly kept and did keep my valves cleaner than that Yamilube. Yamilube is great for Non power valve sleds.Try it,its good stuff.
LFM
- Feb 17, 2004
- Vancouver/Whistler Canada
- www.mainstreetcorridor.com
Do tell.............2001SRX=Fast said:Kinger.... I found a place for 8.99 a liter. Super cheap.
LFM
- Feb 17, 2004
Canadian supplier
http://www.royaldistributing.com/servlet/MiddleRedirect?cat=winter&page=343.html
this is one place to get it for a decent price. CDN dollars
2001SRX=Fast
Okay i went to my Dealer and they said not to use syntetic oil in my sled. 01srx porting and head work... Whats your answers...
yamaholic22
yea because they want to push yamalube? What is ONE good reason not to use synthetic oil? Especially on srx's and vipers, where the intake side of the skirts and cylinders seem to wear more than on other yamaha engines. A good reason not to use better technology, better oils?
MrTriple
I used it from day 1 in my Viper......it's great stuff !! My dealer promotes it for ALL Yamaha products.
There was one local dealer blowing it out for $29.95 cdn 4 lt jug last season.....he couldn't keep it in stock!! Going rate is $34.95
yamyrider
hum...kinda strange when my dealer said they use nothing but IPONE in their own demo sleds. The do not even put a drop of yamylube and go to the good stuff right away
