2002 SRX idler wheels
Lucas 29
Halifax N.S Canada
my Srx came with the smaller wheel kit up front when i bought it. One of the wheels is missing on one side along with the block, and both bolts. I know Yamaha sells these kits directly, but they're like $100 and you can only buy the whole kit. I was wondering if anyone knows if and where you can buy these separatly, or aftermarket to save a few $$$ they are called
marginal snow wheel kits
thanks
Do you have the size of the wheel & what bearing it takes?
If they look like these, I think the wheels are the same as the tunnel wheels
with a 6004/2rs bearing
looks exactly like that. I just need one side though. i was just wondering if you can just buy the one side or do i have to buy the whole kit? also wondering if there is an aftermarket kit available (they're usually way cheaper)
You can get yamaha or aftermarket.
The yamaha ones are about 22.00 & I think the part number is 8H8-47320-00-00 for the wheel &
93306-00444-00 for the bearing (6004/2RS)
You can look them up from TY member Port Parts.
Did you look at the bearing number on your good one?
actually it's' not like the kit in the royal distributing catologue, i checked that one before. That kit may work though. It's like the kit srx maine posted , I'll check and see what i can get it for through yamaha, my buddy owns a dealership anyway, i just know that sometimes even cost on factory parts can be a lot more than retail aftermarket stuff. thanks for the help though!
Lucas, Royal distributing should have Kimpex (aftermarket) wheels the right size.
I found a Kimpex number KX4116105 that is a tunnel wheel, that is the same as
the yamaha part number I gave you.
They are about 12.00 without a bearing.
I think i might have one side,i bought a 2001 srx with the same kit and mine was missing one side too.I'll looks in my junk and see if i can find it.I think i have the block and the wheel.
i tried calling today but i guess i have to figure out where you are located so i can figure out the time change and call when you're open!!lol. I'll get a hold of you tommorrow. thanks
