I am looking for a suspension relocation template to move my skid back to 2000 and newer geometry. I switched from W-arm to H-arm and need to know where the skid mounts are. I know Mtn Performance sells a kit but they only offer it with the billet drop down brackets and I don't need the extra expense. Anyone out there have the template or maybe some dimension? I'm guessing the center and rear mounts are still the same as far as geometry but the H-arm moves back on the rails so the front mount must be changed. If anyone has a 2000 or new Mtn Max and could let me know the following dimensions I would really appreciate it.
I need to know measurements on the following:
1. distance from back edge of bulkhead to front mount bolt
2. height to front mount bolt from the running boards
3. distance from back edge of bulkhead to center mount bolt
4. front mount bolt to center mount bolt distance
5. center mount to rear skid mount on the drop down bracket (tough to get because running board is in the way)
6. front mount to rear skid mount on the drop down bracket (also tough for same reason as #5)
I need pretty accurate measurements on this and any help would be greatly appreciated.
Troy
Troy
