BlueRider17
I'm looking for the aftermarket part #'s for bearings for a 02 Viper ER and a 97 XTC w/ reverse. Are the bearings in the chaincase the same? Yamaha's part numbers are different but from what I can find, all of the late model sleds are the same.
As far as I can tell, the chaincase baearings are 6205 2RS.
Are the axle and jackshaft bearings the same dimensions but just have the collars on them?
Thanks for any help
Thanks for any help
TJ500
the driveshaft and jackshaft bearings are different.... the outer dimension of the outer race of the jackshaft bearing has a small radius to it, where the driveshaft bearing is not radiused, but square... both have collars...
referring to pto side bearings here... and this is for XTC.... not familar with Viper....
tj
tj
n2oiroc
viper driveshaft bearing on the speedo side is a nsk ub205
Waterfoul
Waterfoul
On the bearing it says:
NSK UB205
On the collar it says:
A SS205LLXV8 and H7 also.
NSK UB205
BlueRider17
Thanks for the help everyone.
I have a viper speedo side bearing $20 shipped. Maxdlx
