Exciter clutching specs?
shortstop20
Stickney, South Dakota
Website
www.snowmobilefanatics.net
Does anyone have any pages with Exciter clutching specs along with documentation and pictures that show assembly/disassembly of the clutches?
My Exciter bogs around 40 MPH, we've checked the carbs many times and replaced the needle and seat also. I think it's something in the clutches. It just hits a brick wall around 40-50 MPH. It goes fine out of the hole most of the time....but sometimes I have to feather the throttle also. Does the clutch disassemble somewhat similar to the clutch in my SRX?? Clutch definitly doesn't look the same. ;):D
I noticed that you aren't sure what year your sled is?
Here are the engine codes to tell you what yr you're sled is. The number is stamped on the block above the recoil starter.
1987 EX570L 82M-000101 AND ON
1988 EX570M 85M-000101 AND ON
1988 EX570EM 84N-000101 AND ON
1989 EX570N 86M-000101 AND ON
1989 EX570EN 86N-000101 AND ON
This should help you figure the right yr on your sled.
also here is a sight that will get you a exploded view just follow the link on the right
http://www.yamaha-motor.com/sport/m...ZmF1bHQuYXNweA==/Parts Catalog/starthere.aspx
