Expert Hyfax
nodoo_s
wales maine
What does the expert x take for sliders, ad boivin wants like 45 buck plus shipping. It looks to me like the old skidoo. any one know anything. i have the set for the 121 but they are to short for the 136.
I know they are older Skidoo slides no idea what years or models they work on? 45 seems like a little much but the ones that were on mine were a lot thicker then probably two oem yami hyfax put together
skidoo profile. from like 96-04 models sc10 to current sc10III. doo colors are about 16-20bux per hyfax. find some garland mfg hyfax, they make the oem slides. dont buy any aftermarket hyfax except garlands. the rest plain suck! get whatcha pay fer. ski
It is what is called profile 8. Not sure what model sled I think a old formula III. You will probably have to trim a few inches off the back. Just use your old ones for length measurement.
craig i gave you the answer but i will post for all to see.its for the old c-7 chassis.get slides for a 95 mach-z.if you have a long expert use 95 mach-z LT slides.LT stands for long track.they are 55" long so you have extra to trim off depending on your expert size.black are $20 a pair for 121" and long are $25 a pair.your better off getting them local to save on cost.
Thanks rich for all your help, i will try and not call you for a couple of days.........just letting you know i might have some type of withdrawals though
