I have a 99 SRX 700 and at 3/4 to FULLl throttle I AM GETTING A FAULT CODE FLASHING, APPEARS TO BE 4 FLASHES AT EQUAL TIMMING. THE SLED CONTINUES TO POWER AT 8400-8500 RPM'S. On START UP NORMAL 3 FLASHES. All fluid levels are good, and runs 100% normal below 3/4 throttle. I cleaned my power valves about 75 miles ago and all was fine until now. any ideas? I found the problem, When I cleaned the power valves the #1 cable must of got out of the track on the servo and ended up crossed under the #2 cable. Normally I always check oeration and do a visual after on the servo but this time I did not, all can learn from this mistake, Thanks Bluebullet
