grippper
does the 99 srx 600 primary clutch have a tall cover or a short cover.
grippper
im looking for springs. can i use a srx spring in a yxr primary clutch. they look longer
Turk
TY TECH ADVISER
- May 2, 2003
You can not use the longer stiffer ones or they will coil bind. The shorter ones are OK.
snowdad4
the srx, 98 and newer has the tall cover... this is where they originated from...98 srx-first Yam w/ tall cover...6@700 same clutch, different setups
