Fasterblaster
How do you adjust the carb slides?
I took the carbs off for a preseason clean and inspect and noticed the clutch side carb is open more than the brake side. Actually, the brake side is only open a tiny crack.
thanks for you suggestions/instructions
Fasterblaster
Allright, i found a fantastic pictorial and narrative by NY SXR. Solid work.
Next question, what slide height for the master?
