440 SRX Crankcase Bolts/Torque Spec
VinSRX80
Neenah, WI
1980 SRX - Anyone have a diagram that shows what lenght bolts go into the crankcase? Also what would the torque spec be and what is the patteren? Thanks alot. Kev
pattern is (w/the crankcase facing you and the pto side to your left) top row(4bolts) left to right is 6, 3, 2, 8 bottom (row of 4) is 5, 1, 4, 7. torque spec is 15 ft/lbs. hope this helps, don't have the bolt lengths. let me know if you need any more info. i have the vintage yamaha clymer service/tech manual
