yammiman
Found this thread through the search section - is the Artic Cat paint still one of the better exhaust paints? - or do you guys have some other suggestions?
http://www.totallyamaha.net/forums/showthread.php?t=8038&highlight=exhaust+paint
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
I am going with this stuff when I finish my pipes. It is good till 2000 degrees it says. No worries there.
http://store.summitracing.com/default.asp?target=partdetail.asp?part=VHT-SP102
yammiman
Thanks - I'll try it
NY AttakGT
They sell that VHT brand header/exaust paint at AutoZone stores, if you have them by you. I just painted my exhaust last week with it. Looks sharp. But the pipes are going to be wrapped so not gonna see much of them anyway. Hope this helps.
--Steve (O.C.)
--Steve (O.C.)
Brad
- May 23, 2003
The high heat ceramic paint by dupli-color from walmart works great as well
yammiman
Alot of AutoZones around here - I'll check it out
B2SO
- Aug 18, 2003
Hey yammiman , when you get everything painted , let me know and i can bake them for you , i use the cheap stuff from meijer thats good up to 1500 , but you need to bake in a oven after there painted to get the full effect , the old man runs a plastic factory in east lansing and they have huge ovens i use to bake all my stuff after being painted ..
duplicolor header and exhaust paint with ceramic,many colors,used the white on my sno-blower engine looks really good.
nailsandrails
I also use the dupli-color from Wal-Mart. It is the best I have found. I paint one pipe at a time and put a heat gun in the end of the pipe. It's the closest I can come to baking it on.
It works well and the pipe does get very hot from one end to the other.
yammiman
Thanks for all the info guys - B2SO - I might take you up on the baking, as long as I can bring some cookies to bake at the same time! LOL
B2SO
- Aug 18, 2003
Yammi , Just let me know when your ready , the shop is open on saturdays also , we can through them in the over and go grab a burger over at paul reverses (sp) let them bake an hour or so and go pick them up , or i can stop by and grap them bake em and drop them back off . let me know ..
yammiman
Sounds good
montynormand
why not just have them ceramic coated? just hade my race pipe done by perfromance coatings out in washington. less than a 10 day trun around
yamyrider
thats an easy answer $$$$$ Painting the pipes is about $15.00
