max
- May 6, 2003
Is it normal on a mountainmax 700-01 that it takes long time before the sled goes down to idle.has it something to do with the clutching?my belt is new.thanks
Do you have pipes on that unit or stock??. If you have pipes then you may have to flip the enrichener real quick to bring it back down. but if its stock pipe i think it should come down right away.
Tod
Tod
jwiedmayer
fuel screws
Turning out the fuel screws just a bit will help.
max
- May 6, 2003
It is stock,with needles down one half,fuelscrews 1,5 turn out.
If flipping the starter (usually called the choke) lever quickly brings the rpm's down, then you have a lean condition.
