heat exchanger install
yamyrider
Northern Ontario
I am upgrading my rear heat exchanger to the bigger SRX/Viper rear exchanger.
My 2000 SXR uses the smaller size hose. I know this has been done but I cant seem to find the information on the hoses.
Any ideas. Thanks.
I'm pretty sure all you need to do is slide the smaller hose from the running board exchanger into the larger hose off the rear one. Apply a little permatex to glue em together. Also use a hole clamp to hold them together.
