Ok, I'm pulling the suspension on my 99 SRX....got the back 2 out just fine, the clutch side front bolt isn't so bad but it's the exhaust side bolt that's pretty much unreachable. I don't have like a 12" socket extension (I REALLY wish I did right now...) so that's out.
My question is this: what's the easiest way to get the front right rear suspension bolt out, WITHOUT removing the pipes...IF that's even possible...
Many thanks in advance!
without sounding too much like a wise ***, simply walk to your neighbors and borrow a 12" 3/8 extension, or hop in car and head to sears, it will make life much easier for the less then $15 youll spend.
there is a cut out in the foot well to get wrench or a short stubby socket...but it will be a bitch.
YAMAHIZAL700
i found a 14mm ratchet wrench to work perfectly get a set of gear rench or craftsmen little pricey but well worth every penny
