Viper 2002 Gearing Question
lazeit
The Zoo
I put a 1.25 track on my Viper and to do this you need to replace the drive axle wheels with smaller wheels for track clearance. When you do this you need to change your gearing to maintian proper gear ratios. My question is, does anyone know what gears I need to install to maintain stock gear ratios?
Thanks in advance.
you don't need to change the wheels unless you're studding the 1.25 track. If you are putting 8T drivers in you need to up your gear ratio by .2, so if you have 1.73 now you need to go to 1.53
