sandmanmike1
Looking to modify clutching for trail set-up in my 94 VMAX 600 ST long track.
Stock is as follows
Gearing 20/39
Primary spring
color L-Y-L
length 78.mm
Pre-Load rate 25.0kg
Weight 8 ay-17605-10
Weight rivet steel 17.2 mm
Weight bush Duralon
Secondary spring
Color P
length 85mm
pre-load rate 60. deg (B-2)
Stock is as follows
Gearing 20/39
Primary spring
color L-Y-L
length 78.mm
Weight bush Duralon
Secondary spring
Color P
length 85mm
