NBviper
Anyone know how accurate the speedometer is on the Viper?
Not very, like most sled speedos. Firgure about 10% off on the big end.
NBviper
Master of Faster said:Not very, like most sled speedos. Firgure about 10% off on the big end.
That would explain why I showed 121 last year.
bucky
mine actualy is right on....107 on radar..that's all she has!
Zom
I've seen some posts that say if you remove one tooth from the speedo gear, it will be almost dead nuts. I may try that myself this year.
Does anyone know if the odometer is accurate? Will changing the speedo gear also change the odometer?
zom
zom
n2oiroc
if the speedo is high, so is the odometer. mine did 105 on radar. the speedo was reading 123! lol!
mine was 124/111
NLViper82
Mine showed 130 on the speedo last year. Good for the ego, but I wanted a realistic number so I cut off one tooth on the gear to try. Hopefully it works.
