MountainMax
ON the TY tech section there is a place there to make a ship to turn your ski's into Rocker Skit like on the SX-R's, My questions are will my MMax benefit from this? is it only the SX-R that has them stock and which way do you install the ships, there are three layers to make it, do the smaller layer go down or up???? there is no instructinos on mounting them or listing why this is a good or bad mod? any help please?
it really doesnt matter what side goes where. But I put the small parts down and this was only offered on the SX-r skis and really helped on the SRX to help with the hard turning effort.
MountainMax
Thanks, I just put a wider front end on mine and that will make itharder to steer so I think this may be a good mod for me to do.
aSRX600guy
I don't see why a wider front end would make it harder to turn.
you could also put on wider handle bars to make a sled easier to turn
grizzly660
- Jul 16, 2003
I put a power steering unit on mine off of a 1979 ford 3/4 ton pickup, really helps when boon docking
MountainMax
I am not sure why it would, but someone told me that it would, then I read about the rocker skis and wanted to do it, anyone know what 60 thous is in inches? like 1/8 thickness????
.060 is slighly under a 1/16" .......0625 is 1/16" and .125 is a 1/8"
MountainMax
So how do I buy 0.60" aluminum, everywhere I check they sell it by 1/8 or 1/16 or 1/4 thicknesses.
1/16" is close enough.
vmaxjohn
Pst...Flat skis float better in deep snow, and are less nervous going down a trail. I personally think rocker skis are way over hyped, and don't deserve the attention. I've got a set of 7" wide C&A's I'll sell ya, they float like a mother!
actually a more aggressive ski all togather such as the C&A's due both, float and carve. Thats what I run. BUt they take more steering effort and that what the rockers achieve. Less steering effort.
ekimsx600
If I change the skis on my 99 sx to rocker skis, do I use the same wear rods?
if you make the rocker inserts, yes, same bars
