snomo101
Anyone know the best way to remove grease from a coat?
terret725
i usualy use a bruch with alot of detergent and scrub teh heck out of where it is let it sit for an hr and then wash it in warm/cold and my HJC still looks like new otehr then the broken zipper little handle thing and the bottom button i closed in my truck door
blueblooded
My wife washed mine with oxy clean,it looks like new now.
PowerValve-700
^^^ Same here, I use Castrol SuperClean.
snomo101
Thanks Guys! Castrol Super Clean? Wow that seems a little harsh. That stuff will eat your side panels if left on to long.
PowerValve-700
I used it on my coat about 15 times and never had a problem so far, just throw it in the washer right away, use hot water a bit of regular detergent like Tide or Sunlight.
03viperguy
actually found that abit (maybe as much as a cup) of simple green works pretty damn well. it is a degreaser, and it isnt harsh
woolyviper
Use Starting Fluid. I used to work in a trucking terminal and had grease on dress shirts and jackets all the time. Works good and leaves no residue.
ViperTom
About $5 and a trip to the dry cleaners will usually do the trick.
Tom
Tom
I have a 05 blue and white yamaha fxr jacket and got rope grease on the arm and this what I used to get it cleaned safely.
1. Fast orange hand cleaner (citris type) only. Ace Hardware.
2. Clean white tee shirt cut in 6x6 pcs to be used as rags.
3. Add the fast orange cleaner direct (DRY) to surface and lightly with white tee rags and rub to clean.
4. Rinse thourghly and repeat if necessary.
5. After clean, wash with Oxyclean per directions or just the area.
My jacket looks like new, good luck.
ViperTom said:About $5 and a trip to the dry cleaners will usually do the trick.
Tom
If it's made of Gore-Tex, I'd suggest NOT having it dry cleaned.
Shhh, that's supposed to be an industry secret.woolyviper said:Use Starting Fluid. I used to work in a trucking terminal and had grease on dress shirts and jackets all the time. Works good and leaves no residue.
Works great as a parts cleaner for the same 'no residue' reason.
