srx with vforce3 help
mikef700
Stock 00 srx, i instaled v force 3 becouse i have 6500 miles on my sled, i thought it was time to replace them,,, but now she"s got no nuts.
it wont pull past 8200 rpms. last year it was a rocket pulled to 8600 rpm every time, 115 on the speedo, not any more. i thought it felt rich i droped a jet size ime know at 147 mag and 146 other two wich is stock jeting, this used to be a lean set up but it still seems rich, cardbord brown
plugs,clutching hasnt changed, but ive cranked the secondary to 9-and 3
backshifts great but still wont pull 8600 ? what the #*^@**
i even did a comp check all 3 were a little over 100 psi, when hot.
i also cleand my power valves, and watched the open when it was runing.
somebody HELP me. ime embarrassed to go to the lake,,, help
100psi is low for that motor. Maybe it's time for some rings!
If it's really due to the reed change, just go back to stock and sell those Vforce. They don't help a Yami much, by all accounts.
srx
with that many miles it's time for new pistons rings and get your cylinders re nicasiled. I have a 2001 SRX with 9000 km just redid mine it was time
srv
Mine had 135 psi on all three
with that many miles the piston skirts shrink witch allows the the piston to rock back and forth and waring the ring edges causing blow by. this only shows up at W.O.T .The sled just can't make enough power to pull the load
and the cylinders will need to re nicaciled
