I have a squeaking noise from the clutch area at idle????? Goes away if you give it some throttle.
BLUEBALLER
Your belt might be too tight. Check to see if you have any washers/shims underneath the three bolts on the back of your secondary. I just installed 2 washers under each because my belt sat way low, but 2 was too many. Same thing you had, squealing belt at idle. I now have one washer under each bolt and squealing went away. Belt is now flush with top of sheave.
Hope this helps.
Hope this helps.
