Needed: Shock installed length - Viper
ecopter
Staunton, Il
I have a set of '02 Viper shocks (original). If anyone has an '02 Viper Manual, could you please help with giving me the installed length for all the shocks: front, center, rear?
I'll need the installed length, the minimum adjustable length and the maximum adjustable length. It's usually stated in millimeters with inches in parenthesis.
Thanks,
Jon
rear suspension shocks adjustability (center of top bolt to bottom of adjuster nut)
length front max 96.8 mm (3.81") std 86.8mm (3.42") min. 76.8mm (3.02")
length rear max 80.3mm (3.16) std 70.3mm (2.77") min 60.3mm (2.37")
ski
Eric,
Just to clarify, you're taking the measurements from the center bolt hole to the adjuster bottom adjuster nut? Or in other words, the bolt hole on the threaded side of the shock to the adjuster nut, right? (very short distance)
Also, your above specs are for the center and rear shock, are they not? Would you happen to have the ski shock lengths also?
Thanks for you help.
Jon
yep, just like you worte it. center of bolt to bottom of threaded adjuster nut (like in the manuals)
front ski shock (same bolt hole to bottom of nut on adjuster)
max 138.5mm (5.45") std 128.5mm (5.06") minimum (soft) 118.5mm (4.67")
the sled manual does not have closed and open eye to eye lengths for us, the service manual may have them. ski
