Drop down bracket for rear skid
Almost700
W Michigan
I just finished my 136 conversion on my Viper and it turned out great. The back of the track sits a little high for my liking. What have you guys done to cure this. I don't want to suck up the straps all the way! If a drop down bracket is the answer, what one works the best? RX1, warrior, Mtn Max?
I believe skidooboy sucked his straps when we did his 136, but you would have to ask him. If you do get drop brackets, go with the MM ones, as they will be cheaper, lighter and will handle the task no problem
im using rx1 drop brackets and they are definatly not a bolt on. they will give about a 2.5" lift at the rear mount. the brackets are $15 eack and i picked up the narrower shaft (needed) for $25.
