Viper front shocks on SRX????
leeko
Chicago
Has anyone made a bracket that accepts the clevis mount Viper shock on SRX or changed the Clevis mount to an eye mount on the shock? Any help would be greatly appreciated.
thanks
LEEKO
I will try to get a better pictures up, but basically what i did was press the clevis mount in a vise against the aluminum spacer, added nylon washers and used a nylon lock nut, not to tight to allow movement. I picked up the spacers from a buddy who put Viper shocks on his SX, they came out of the top mount, worked out pretty good for me!............James
I have thought if that, the bolt is snug in there but i may look at inserting a metal busing like in the ski mount, would have to enlarge the hole in my spacer and the shock mount, if i remember Maddog had a friend who did this last year they claimed no problems, but this is all work in progress...........James
Oh, i just though of something, i also got from that SX the upper shock bushing, the one with rubber and metal bushing, i might look at that, may have grind the ends off little to fit the pressed mount i modified but that might be the cat's a$$.....James
Anyone Ever Put The Viper Shocks In Upside Down With Clevis Bolting To Trailing Arm With Modified Alum. Bushing?
