Hi, my friends 2001 MM idles rather high all the time, you have to blip the choke to bring the idle down from 4000+ to 2200 or something which is also too high. It also stumbles when you give gas if you have ridden and stopped for like 10 minutes or the motor is cold. I know I asked this question before but I forgot the answer. Can these 2 things be correlated? How to fix it?
thanks
thanks
yamaholic22
are the carbs clean? Dirty pilots will do this. Does it have reed spacers or the reed stopper notch? This helps out a lot for the stumbling in the low end and midrange. As for the high idle, open the fuel screws to 2 turns out from lightly seated position and it will fix that.
LFM
- Feb 17, 2004
- Vancouver/Whistler Canada
- www.mainstreetcorridor.com
sounds like carbs to me
