FuninAK
AlaskaJeff
At work and thinking........If I went with the big wheel kit for my MM could I fit a 144" without rail extenders??? My budget will NOT allow what I really want to do: the full 151 swap, so this MIGHT be a cheaper alternative to a little better footprint and ditching the HEAVY stock Yokoload 141. LMK what ya think.
Seems like it might work. With 50% wrap on the rear idler the usefull difference in circumferences between an 8 in wheel and a 7 is about 1.6 inches so you might be able to suck up the extra track length for a while with the adjuster plus slightly bigger wheel. But don't most kits move the axle forward and up to compensate for the bigger wheel effectively gaining you nothing in length.
nben
Just finished mine last night and that's exaclty what i did. I used an axle from HPE and three 8" Fabcraft wheels. HPE sends different axle adjusters with their kit so a little drilling is required but nothing real serious. I was very happy to get rid of that heavy Yoko 141. I'll take some pics tomorrow for you.
Nate
Nate
mountainman
u can move the hole skid back but it mite mess with the approach angle...i have a 151 and u can geta 151 from tracksusa for 319 brand spankin new!
dnt know if its a huge difference cuz i never rode my sled stock i bot it modded
Boondocker-1
If your on a budget it would be much cheaper to get the rail extenders from Mountain Performance. Wheels are $80 to $100 each plus the axle is $100 or better so your looking at aprox. $300 versus buying extenders for about $100. Look at ther web site.
www.mountainperformance.com
Boondocker-1
Here is a better link just scroll down once you get there.
http://www.mountainperformance.com/yamaha_rear_suspension.htm
FuninAK
AlaskaJeff
Thanks guys
Some excellent info from everybody!! Now I have more to think about.
nben
My axle was $128 and the wheels were $45 each for a total of $263. I thought about going the rail extension route too but I really like the look of the 8" wheels and they are LIGHT with a capital L (althought the axle is a little heavier, but I went with only three wheels which saved a little).
If you really want the footprint but don't want to spend the $ for the tunnel extension (151") consider a 16" track. There is plenty of good advice about the topic if you hunt around a little and they fit the tunnel with little effort (what I have heard but not personal experience).
Boondocker-1
More on the Big Wheel Kit
There is an article about Big Wheel Kits in the October 2005 SNOWEST Magazine. Gives some pros and cons. Its a good read.
nben
FuninAK
AlaskaJeff
I Like!!
Thanks, it looks great I see your x-fer straps are set pretty tight. I just put mine on and I've got them on the +3 setting and they are a bit looser than yours. Have you reun it yet this year?
nben
My transfer straps are set in the 0 position right now. I have not had a chance to ride this sled yet this season(except in the driveway, and it carried the skis great!). I expect it will take a little tinkering to get it where I want it.
Nate
Nate
