Opticool Head Gasket
charles
brampton ont.
What is the difference between the opticool head gasket and the stock gasket? Just received my new head gasket from MPI, was supposed to be opticool but there is no part number on the packaging so I don't know if it is the opticool or stock gasket.
Charles
charles, mpi does alot of stuff with bender so you probably got a opticool gasket. what you can do when swapping them is to over lay the new and old gaskets you will see the cooling port size difference in each gasket, with the opticool having larger, more precise coolant passages on the gasket. if you have it tore down fairly far, you can benefit the coolant flow by adding an srx base gasket to the viper also. ski
