Removing oil and water pump shaft??
jaydaniels
Amherst NS
Anyone know how to remove the shaft which runs your oil pump and water pump? I have a 98 SRX with the crank split and thought it would be a good time to replace the seals and bearings on this shaft. I noticed that the shaft does not turn very easily by hand and it seems like it is spinning inside one of the bearings without the bearing turning. I figured this might be a bad bearing but not sure. :o|
