next mod??
pi center dumps,
2 layer gasket
clucth weights and spring
ohlins in the rear
ultimatetraction 1" track
144 studs and 388 lug screws(dirtbike studs)
i got some vipers skies on there and im lookin for some rods but not having any luck i keep checking the pages and there eitehr off a SRX or they just got rid of them
Just get a new clutch kit but make sure it will run with the pipes you got... other wise get a new track or transfer rods
i got the clucth set up for the pipes got 89Ls with 2.5 grams, ysy spring on the primary, stock spring and 45* helix and a 60* twist. if any one has tweeks for tehat cluct set of for a little more snap id liek to know.
oh yea i have reed spacers too.
sounds like you pretty much have it set... what year is it? if it doesnt already have it, go for a dual bulb setup and seperate hand/thumb warmers. always nice :)
get the rear SRX heat exchanger. WHen running the pipes and thin head gasket I would want more cooling. Do you have reed spacers or noth done.
I have the 2000 SXR as well with Aaen tripples, clutched, reed spacers, thin head gasket, Polaris rear idlers, camo track and I installed a SRX rear heat exchanger for extra cooling to be on the safe side.
