dual carbides are ONLY good for eliminating darting. Do you have darting problems on your srx? Darting is not very common on the srx's, and if you do have it it is probably a matter of setup. Dual carbides dont bite near as hard in the corners, and they take away quite a bit of top speed because it takes a lot more effort to push their width through the snow. This is obvious if you have ever tested them in the same conditions, single carbides then switch to duals. The push in the corners is where they really stink.
