Bushman
What does it take for a Warrior to run with 136" piped Vipers 1000' on the snow?
My buddy's Warrior has 1200 miles on it & we keep waiting for the sled to wakeup like everyone says it will...... It has not. It runs good but not Great.
I have a CPR Viper Super Tune kit or Viper Heel Clicker kit (Maynot have heavy enough base weight?) we removed after going with a TEAM roller on another Viper.
50/44, 46/40, 51/39, 47 & 43 helix to pick from, It sounds like the Yami Silver secondary spring is the ticket when set tight (80 or 90) on the RX & Warrior....
We would like a good Boondocking/trail setup if possable to get this sled running with the rest of the crew. Thanks! Bushman
Bushman
OK not many takers, How about if I run the 48.5g base Heavy Hitters with the 3/4 heel, Center 7/16 steel bolt & thin washer, tip @ 3/8 steel bolt & thick washer with the stock primary spring & stock helix & Yami silver set @ 80 twist, How much should this setup gain over stock?
How much more weight will I be able to add if we try the 155/300 CPR primary spring or does it slow the upshift too much?
IBABAD1
- Sep 12, 2003
BUSHMAN, YOU ARE TALKING ABOUT A SET UP FOR THE
WARRIOR RIGHT? NOT READY YET.
Turk
TY TECH ADVISER
- May 2, 2003
Go with 51/39 helix, 1/4 & 3/4 allen in heel. 4.2 bolt with heavy waher in 1st hole. 2.4 bolt with 2- .4 gram washers in tip should be real close. Run it from 9800-10200 rpm.
Bushman
Turk said:Go with 51/39 helix, 1/4 & 3/4 allen in heel. 4.2 bolt with heavy waher in 1st hole. 2.4 bolt with 2- .4 gram washers in tip should be real close. Run it from 9800-10200 rpm.
Thank's Mike! What springs should we run?
IBABAD1 yes this is for the Warrior....
