power valve adjustment
full tilt viper
Southern Ontario
I've been reading the previous posts about adjusting the power valves without a tester. I completly removed the valves for cleaning reinstalled them. It has been about 3000k without an adjustment. The sled pulls good rpm but i want to make sure the in the right spot! With the servo cover off 2 cables has some slack 1 does not. When i run it under a 1000rpms, let it stall and mark the servo position will the valves be pulled back in that position? How can i tell if they have moved all the way in or out? Also when do you adjust the cables themselves? I don't want to mess this up.
