Im in Chicago thanx for the offer!!B2SO said:i have a 25 top gear if you want to run a 34 bottom gear , it would be the same ratio , and i would give it to ya cheap !!!!!if your in the usa that is , its almost not worth shipping across the border anymore ...
I was happy to get a solid answer!! He had me at a 25/35 then I told him about the 780 kit and he changed it to 24/35. Im just starting to learn about these things so it helps to here from other people. Do you think it will come out of the hole okay with this setup? Thanx againSRXtrafast said:Those guys at Maxx Perf know their stuff. Like I've posted before I run a 25/35 and 8 tooth drivers which gives me a 1.58. No hole shot lag and she rolls. You wouldn't be hurt running that esp. w/a 780. Anyway it sounds as though you're going to kick some athis year! Have fun
2000 SRXSRXtrafast said:I guess I missed it along the way but what did have for a sled?
Im running a ZR900 skid and RIPSAW track 144 picks, and a 8 tooth drive I finally got this thing to transfer can't wait to try this RIPSAW!!!98srx6 said:Sounds like a bb srx.
GS438 traction could be an issue with the 24T, I would personally try the 25T and go from there unless you have no doubts about your sleds traction.
Bill let me no what you have to get for it???B2SO said:I have a 25 top gear for ya ...im in michigan , could have it by monday![]()
Would my weight factor in this decision my fat @$$ weighs 270# ????SRXtrafast said:Probably your hole shot might be better w/ the 24 ,it's the same as shifting your bicycle to the smaller gear at the peddles[less resistance from the start]. But as you keep going you need to shift to a higher gear at the peddles[drive] to go faster. That's why I think you have enough power w/ the 780 to go w/ the 25. If you can get the 25 from B2SO give it a try and see how both work.![]()
