2002 Viper that the tach cycles with high beams and all lights flash when grabbing the brake. Is there any other possible cause besides the stator? no wire shorts found are there relays or other possible areas to check?
My viper did the same thing, seemed like it was drawing power somewhere. I rode it like this for about 200 miles, and then it quit, the stator went completely out. I also found a bare wire under the motor before this happened. Lucky for me it was covered under warranty. I had a stator go out at 2000 miles and again at 4200.
my 2002 viper developed a simular problem this weekend. tach and speedo go dead when going from bright to dim. checked all connections and put dielectric greese on them but didn't help. i still have to check all the grounds , if that doen't work i guess it's going to the dealer.
