hos
- Sep 28, 2005
Searched awhile, couldn't find anything to go on. Pulled power valves out of buddies srx, cleaned them, one was out of adjustment. Tried the best I could to readjust (per tech), but wasn't getting much movement on the valve when adjusting the cable. Figured I was close, put in new plugs (did not go through carbs). Put on stand to adjust track tension and would not run right. TORS was kicking on and figured it was that I had idle turned way down, turned it back up and sled was fine. had a bad bog off throttle but cleaned out high rpm. Then it backfired big, blew pipe off clutch side. Got pipe put back on, and started, still ran like crap and blew pipe off again.
Does anyone have any ideas? Used to work on my own A/C race sleds and now my Polaris, not much I don't do on my own, but I'm baffled. Possibility I screwed it up with power valve adjustment, or just coincidence, and I plugged a jet in carb and blew a cylinder (hasn't been run this year).
pilot jets in carb (plugged)!!! gary Oles nosboy
TopGunnSrx
Id clean the carbs and check the throttle cable for adjustment, also maybe check the exhaust pipes they may have crap up inside of them?
I'm with Nosboy, plugged pilot jet. Maxdlx
