600srxman
hey i just got this srx and i have replaced both voltage regulators and i cant keep lights in it i need help please and the temp light comes on when i get on to the gas thanks (the two wire regulator is out of a phazer)
pro116
Lifetime VIP Member
what year srx?
600srxman
its a 99 600
mrviper700
VIP Lifetime Member
need more information
so what is the blinking sequence on the temp light?
have you checked the wiring harness under the motor????, sounds like its grounding out and shorting the lights, they do all kinds of goofy things when they ground the harness out, another common lighting problem is the harness for the tailight, seen it ground out and take out bulbs and regulators.
600srxman
i dont know the sequence on the temp light right now , what duz it mean??
i have the brake light disconnected right now and today i fired it up and the high beam indacator light was working and it has not worked for the past 3 days im going over it tomorow thanks
600srxman
the temp light flashes 3 times right now
mrviper700
VIP Lifetime Member
temp light blinking
It blinks 3 times when you first start the sled, this tells you its working, its the sequence after that you have to watch for, check the tail light harness real good, it might just be the problem if its working now since you unplugged it
600srxman
ok thank you i will check it
600srxman
when im driving down a feild and i put the throttle to the bar the temp light comes on. when i let off the light goes off
yamaholic22
it comes on and stays on or blinks a code? We need to know what code is blinking.
monkey man
- Oct 27, 2005
check the wire harness under the motor probally rubed through and is grounding out as someoneelse said possible tail light wire rub through either way it is grounding out some where either use a ohm meter or uncover the wires in the harnesses and check them good wireing problems are fun
600srxman
600srxman
no it just comes on and stays on untill i let off on the gas
yamsrx700
I'm with Monkey Man on this one. Mine was doing the same thing. My tachometer would also stop working at times, often at the same time I pinned the throttle when the temp light came on. Does yours do this? Look down between the power valves and the pipes and you will see a wiring harness in the belly pan. The harness goes from the headlight to the belly pan, under the motor and up behind the motor on the right side of the sled. Good luck, they can be hard to find but it should be an easy fix.
600srxman
when im driving down a trail and i put the throttle to wfo the temp light comes on and stays on when i back the throttle off to 1/2 it goes out
600srxman
ok thanks guys
