Fuel Leak??? Overflow???
1 Trick Viper
Rogers, MN
I was studding the track today on my Viper and I had it tipped on the chaincase side, I supported so it did'nt lay all the way over, when I set it back down on the track, some fuel dripped out the bellypan from one of the holes in the bottom and it was a fair amount. I as far as I could tell it looked like it drained from the airbox. Weird thing is that I have done this many times before and never had any gas drip out from anywhere. Something I should be worried about? Anybody have the same problem? Thanks for your help.
carb vents more than likely. you tipped it on its side, float bowls drained contents into vent lines, tipped back upright, and evacuated the lines. they did their job. if you have an attac or tempaflow, make sure to drain the fuel out of the lines or the system will not work correctly and you will have a hard time starting the sled when it is warm. ski
