sol-sask
- Sep 8, 2003
what kind of bogie wheels can i get off an older sled that are 8 inchs....want to put a inexpensive big wheel kit on...
I would just go with new plastic wheels that come with bearings. You will likely have to buy new bearings anyway if you find old wheels.
sol-sask
- Sep 8, 2003
thats my plan i just dont know which older model sled you can get these wheels from.....need make and year...also shaft diameter will make a diff....will have to fabricate plates to lift the shaft up a bit...
I think I have some of the large wheels off a 97 700SX. They are the rear skid wheels and they are red (aluminum 5 slot) I think these are 7 inch wheels.
B2SO
- Aug 18, 2003
77-78 srx
the 77-78 srx is the closest your going to get without changing rear axle they are 7.5 and they will bolt right on ..
wheels
moutain performance sell 8" wheels with bearings for I belive 25.00,check it out.
RXMax
TracksUSA.com also has some very reasonable priced 8" wheels in colored spoked version or in solid black around $20 each.
